1 members (Dandare), 1,870 guests, and 1,220 robots.
Hi all, I’m a 50+ year old concreter, husband and father. Jumped on here to learn about servicing and maintaining Honda engines as our troweling machines etc. are mostly powered by them and I’m sick of getting ripped off by so called small engine shops.
1 member likes this: jamie qld
Hi Not much goes wrong with those Honda's that an internet carburettor won't fix They get a lot of rust in the float bowl that clogs up the main jet You can clean them out but the rusty bowl will still be there I have had to use the gas welding tip cleaners to unclog the jet but that is not s good idea as it damages the jet slightly . They will usually go afterwards but might run unevenly Only expect to pay about $20 for the new carby Those carbys have a drain plug in the bowl .If we just undid that every once in a while and drain the water out we would have a lot less trouble. Jeff
Hi Jeff, and if idiots stopped using E10 fuel in these things then many of these problems would be avoided
Hi Krazypan, JFB and NK,
first, welcome to the board [i]Krazypan[/i], I'm sure you won't be here long if all you have is a Honda OHV unless the equipment it's on gives trouble as well.
A plastic bowl that isn't affected by ethanol would avoid it too.
not only the bowl MF, it is the diecast body that gets destroyed as well
Moderated by  bigted, Bruce
18,141 Registered Users
Members18,141
