1 members (GregM), 1,194 guests, and 1,070 robots.
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
by vint_mow - 30/04/26 11:02 AM
by vint_mow - 30/04/26 10:50 AM
by looktall - 29/04/26 02:48 PM
by AVB - 28/04/26 09:59 PM
Rover Rancher 1766 Ignition Barrel wiring
by RayWill - 27/04/26 06:55 PM
by vint_mow - 27/04/26 06:02 PM
Rover height adjust plate
by vint_mow - 27/04/26 08:24 AM
by vint_mow - 27/04/26 08:23 AM
by Lenoleno77 - 27/04/26 07:55 AM
#10929 21/01/09 05:38 AM
My four stroke Rover EasyStart (Model No 30026w) started fine as usual and then died. No spark.
The plug is good, the gap is right and the coil is a business card away from the magnets. I suspect the coil.
Is there a way of checking a coil using continuity? My circuit tester shows open circuits everywhere; from the tip of the plug lead to every component of the coil including the tag for the cut-off switch.
Is this right? Shouldn't there be some bits isolated from each other so there is a potential difference to make the plug spark?
Rob
Publicity Officer
Victorian Rock'n'Roll Dance Association
www.VRRDA.org.au
www.VicRock.com.au
RobE #10932 21/01/09 06:11 AM
what motor is on it? thanks.
#10933 21/01/09 10:05 AM
a quick google search netted one referal to that model number. it appears you would have the briggs sprint 375 motor.
Is the black wire coming from the coil shorting on anything? if not it would be fairly safe to assume the coil is gone.
here is a link to one for sale on ebay,http://cgi.ebay.com.au/Briggs-and-Stratton-4-Stroke-Engine-parts-Coil-Pack_W0QQitemZ300287044590QQihZ020QQcategoryZ126023QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
if you want I have a few second hand ones which I can test one and post to you for $10 + post.
#10942 22/01/09 03:51 AM
That is great Joe. I appreciate the support.
I am embarrased to admit that I went back through the diagnostic process one more time for luck, tried a new plug and, you all knew anyway, it fired up like a charm first pull.
However, I would still like to learn how this sort of coil and timing actualy works. I am struggling to visualise the circuit that creates the spark.
Rob
Publicity Officer
www.VRRDA.org.au
www.VicRock.com.au
RobE #10944 22/01/09 04:02 AM
Not sure how basic an explanation you are looking for, but if you are a raw beginner on magneto ignition this might give you a start:
http://science.howstuffworks.com/question375.htm
RobE #10945 22/01/09 04:13 AM
In case you wanted a technical answer, here is the circuit diagram for a breaker-point magneto. Although the diagram shows a one-to-one turns ratio from primary to secondary, in reality it is about 100 to one: lots of secondary turns, which is probably why your circuit tester showed the secondary as open circuit. It has quite a high resistance, but you should be able to test it with a resistance meter.
grumpy #10958 24/01/09 12:25 PM
Thanks Grumpy, just the info I was looking for.
Best wishes
Rob
Publicity Officer
www.VRRDA.org.au
www.VicRock.com.au
Okie, Jones666racing, EasyMoney, Port Fairy Lawns and, RayWill
17,940 Registered Users
Topics13,089
Posts107,393
Members17,940
PHP: 8.3.30 Page Time: 0.051s Queries: 31 (0.044s) Memory: 0.6434 MB (Peak: 0.7009 MB) Data Comp: Zlib Server Time: 2026-05-01 12:47:20 UTC
