1 members (Red Rum), 11,983 guests, and 419 robots.
GMC 750W Generator
Suring problems
Rover 53179 Autodrive
by Markh - 28/06/26 12:20 PM
by Renzo27 - 27/06/26 07:58 PM
Rover Rancher info
by Bruce - 26/06/26 11:07 AM
GMC 750W Generator
Suring problems
Hi Sparker,
Now I'll if I can do something like that, but maybe I have a broken conrod......It was going OK, revving a bit then stopped.......... dead
My mate doesn't want his motor back, but I'm trying to get the AC generator off......
As his dad has a 5hp B&S that might do the job
.speedy
speedy, the difference between your motor and Sparkers is his case was broken but an object flung at it by the mower blade, yours is broken by something being flung at it from the inside and that is never going to have a happy ending
Hi speedy
Can't see that ending too good.
5hp might do the trick, what is the gen powerhead rating?
Dunlite?
Yep thats a conrod. Few problems with putting a 5hp on there.
Being a generator the engine will have a tapered shaft. So unless the 5hp you have came off a genset, you will have a problem
The mounting flange on an 8hp is well different to a 5hp
Not to mention the power difference. With nearly half the power going in you'll get less than half the power out of it when accounting for losses.
Up to you ultimately, but I would either look for another engine or scrap it for copper value in the generator
Thanks for tips nath.
Tyler its a Dunlite
3 KVA 12.5 amps
2.4 KW 10 apms
240v
Speedy, I think the pressure in the sump area, where I did my repair, is lower than the area damaged in your cylinder wall unless there is a lot of blow-by and, as the others have said, I didn't have an internal engine failure like you have had.
July
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
bjm8, snell96, geoffhurst83, PXM71931, maxgara79
18,020 Registered Users
Topics12,739
Posts106,730
Members18,021
