2 members (Commspares, aitchey), 2,155 guests, and 1,441 robots.
Norm, the self propelling is stuck on engaged, locking the wheels in both directions. Cable is faulty but I have a feeling that isn't the only culprit. Previous owner claimed it has a faulty clutch and the mower had been in storage for 20 years.
I can believe that last part as the base is in good condition. If only I had a catcher for it. It's a fantastic looking mower.
I very much doubt the cable is the problem because with these the clutch is always disengaged until the cable is put under tension. This indicates something is wrong in the gearbox or the axle has locked up in the bushes, but this is unlikely. As Speedy said, remove the belt and the gears in each wheel and it will be a good push mower and once you remove the belt you can start on getting the motor running. You can't with the belt on and gearbox locked up
Thanks for that info Norm. I had to have it up on wooden blocks with rears off the ground to see if the engine would start. It worked at first (with wheels turning at the same time) and then the motor made a popping sound and stalled. It wouldn't fire again.
My theory, a seal had hardened/ perished from prolonged lack of use.
Or the load being put on the motor by the transmission is causing too much resistance for it to start. You will not know till the belt is removed.
Tested it today, starts so easy, good power, but the height adjuster is stuck.
I thought it was the rear drive gear and alxes, so as my mate said the gearbox was siezed.
I thought I would take the gearbox off and fix the height adjuster as it was mowing too low for me.
I studied the diagrams and couldn't figure it out, but undoing a few bolts, got the axle/gearbox assembly off.....
Anyway I cut the gearbox off, it's not pretty............
I thought , this will be good, less weight, plug that big hole with a nice plate, and I'll have a nice mower.....
Fitted the lightened axle assembly .... without bolts just seeing how it fitted, and the adjuster was still jammed.......
The front axle /plastic bush must be rusted up.....
That's the next job, after I make a nice plate for the hole in the base.....
I was going to give the gearbox parts to anyone like MF was wanted to restore one, but that didn't work.
I assembled the rear axle , patched the whole.
Took off the front axle, sheared a bolt, drilled it a bit, but it was through a aluminium lug so I couldn't wack it and break the lug off, so I ground flats on each side of the bolt and it loosened....cleaned up the axles, greased them with plastic bushes......put together, adjuster works well now.. haven't finished yet...
See the rust in that bush.....that's why they were siezed...
Old machines are a chalange, but it's a blast to see them even half restored like I do...... and reuse them.
Hi Speedy,
I'm just a bit curious as to at what stage you got really angry with the gearbox laugh
What are you talking about Norm? Just a couple of goes with a flat headed screwdriver will have it functioning again!!
Just keep chipping away Speedy. Great progress you have made in making this into a fully functioning push mower. Show us the patch you end up making for the SP opening on the base please!
I couldn't take gearbox out easily, it looked like I had to grind steel rivits off and rerivet them, but as it was stuffed, I made the dicision.......... it took some cutting and cold chisel bashing....
Here's the patch MF..... and the bodgied top white piece......
Finished off today, not as nice as the one already on ODK but I'll be mowing with this one.....
That Boston Bright Zinc is nice on the handles...
Looks fantasmo Speedy. Mowerfreak approves of those silvered front wheels to match the rears and the improvised top grill.
A stylish number we have here. Looks like Vortex's full crank brother!
Great refirb using what resources you had, on what was a sorry looking mower not long ago.
Now to find a catcher and perhaps a repro decal for the cover which are available on eBay. He's a keeper!
No sell MF, it's my Darft Vader mower..... starts so easy... that's why i like it....
I don't need a catcher........ hate them.....
It does look like it's out of a Star Wars movie (which Disney keep churning out).
You're all set then, with or without a catcher!
18,145 Registered Users
Members18,146
