G'day everyone,
Hi Mowerfreak I know mine emits a bit of smoke mainly on first cold start up, then it's usually not that bad once it gets up and running. I think it smokes a bit more when it's just ticking over at a slow idle than what it does when it's up and revving during mowing. You could have an old tired engine maybe, I did have my engine rebuilt back around 2008 or something.
Hi Tyler, yes I also think on my carby there is no letter markings on the poppet valve it's just a plain black valve. Sorry to hear about the flat battery on your car mate. The last time that happened to me was once I forgot to turn the parker lights off after a drive. Tried to start the car the next day and the car wouldn't turn over at all. Ever since that happened I make sure I check all lights are off before I leave the vehicle. I even look at the lights as I walk around the car to make sure they are all off...lol
Cheers!
Posts: 4,675 Likes: 165
I had a 95 Toyota Lexcen (VS Commodore) that switched of the headlights when you opened the door. My 89 Laser lets of a high pitched noise when you leave them on and turn of the ignition and 1992 Fairlane Ghia beeps at you with the beeps gradually speeding up and getting louder.
Posts: 2,101 Likes: 81
Hi Converse & MF, managed to start it (just) with its own power. Cranked slowly, but kicked into life. The door was on the side near the wall, so I didn't see it. The headlights go off when the key goes out of the ignition, but the door marker light comes on every time the door is open/ajar.
I put the old faithful standard PT over the lawn today (bit thick and a little high), it has the poppet on A - it certainly smoked more under load only than my PT commando on Poppet B (not the FC commando) and didn't like revving up as much on the thick stuff. Governor is fully operational with good diaphragm, spring, etc. Will change to B mark one day and see if there is any difference
Regards Tyler
Posts: 8,191 Likes: 233
I just set them all on "C" and I don't use the black poppets. I know this works so I don't mess with it I set all the carbs up the same with 3 washers under the cam but the occasional one requires 4 washers to get the poppet to close off and bring the revs down for idle position
Topics12,730
Posts106,679
Members17,978
