0 members (), 3,975 guests, and 286 robots.
by Bumps - 19/03/26 11:57 AM
Mower wheel ID.
Shout Box
by geobee - 14/03/26 08:36 PM
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
by Bumps - 01/04/26 05:37 PM
Mower wheel ID.
Eaton Model 6/7
by Bruce - 20/03/26 09:50 AM
by Bruce - 19/03/26 11:52 AM
Shout Box
by Bruce - 16/03/26 08:10 AM
Early Morrison rotary mower
#72220 05/02/16 07:29 AM
seanw
how does this thing work?
Spark plug cleaner, the seller wants 280
motorwannabe
Hi Sean
Oh, it just does things inside the thing.
I don't know how they work - sand and air blasting?
One for Gadge or the mechanics here.
I was just waiting to see what you knew about these, Jack. grin
Yes, these are indeed a mini abrasive blasting unit, powered by an external compressed air supply.
Bad karma for a small engine shop. To quote my 1981 version B&S Repair Manual [their emphasis]:
Spark Plug Cleaning
Clean spark plug with a pen knife or wire brush and solvent and set gap at 0.030" (0.75mm) for all models. If the electrodes are burned away, or the porcelain is cracked, replace with a new plug. DO NOT USE ABRASIVE CLEANING MACHINES.
They were particularly verboten with Victa, as the sticky 2-stroke fouling could trap abrasive grains. To later cause disaster, when they re-emerged in the bore...
The only places I've seen that actually used this type of machine were aero engine maintenance workshops.
Aero engine plugs, as well as being large and expensive, are very prone to lead fouling when 100/130 [or even 115/145!] octane number leaded aviation gasoline [avgas] is/was used.
Not so much a problem with the current 100LL [Low Lead] avgas, but even that has twice the lead level that the old Super grade leaded motor spirit had.
prd Offline
MOD & GREENFIELD TECHNICIAN
It's also a tester. Vibrator and coil provide HT. plug is screwed in where shown in the photo and the spark end viewed thro the little viewing glass just in front. Compressed air is applied to the chamber the plug is screwed into. The gauge is supposed to give an indication of pass or fail based on compressed air charge and gap (?)
Southern Cross Registrar
Yes I have a restored one different model and work as above
I use mine to test magnetos
Ian
I'm old enough to remember using one at work, that was back in the days before "just stick a new set of plugs in it" became the thing to do.
Found an ad for the spark plug cleaner
Dated 1977
Ian
That's brilliant Ian.
Not an un-handsome piece of industrial design.
I'm trying to work out where it went on the Jupiter Two ... grin
Moderated by  Bruce, Deejay
Pazzaboy, mgman, Drennie, RobNich, JLAU
17,905 Registered Users
Topics13,076
Posts107,348
Members17,905
PHP: 8.3.30 Page Time: 0.036s Queries: 31 (0.031s) Memory: 0.6544 MB (Peak: 0.7011 MB) Data Comp: Zlib Server Time: 2026-04-04 01:37:51 UTC
