1 members (Burra75), 1,613 guests, and 3,371 robots.
Page 2 of 3 1 2 3
I have to Agree with Jack...I'm really hoping you can complete this little gem with the aquisition of a base and parts.
Thankyou also for breaking down the engine, as engine building/restoring is one of my main passions,and this is one I've never had the chance to build. I really like the fact the casings still retain alot of their original casting lustre after so many years.
Im quite excited about the restoration,as this is one very elusive mower id really love to see complete.
Please keep your progress info coming.
Spent most of the day cleaning parts, the spare magneto cleaned up nicely. It has no condenser, I am wondering if anyone knows what one will do the job, I have plenty of spare Victa ones. Would one of the Victa ones do the job ?
Victa condenser should be fine...I occasionally use the later Special conds on the Rotomo wipacs,when I run out. Never had a problem.
Do you have an image of the original condenser on your good engine? Should be the brass one with screw on connection.
Thanks Mal, no original condenser to view. My other magneto already has another in its place, I think they were a long thin one with a nut on the end from memory. I will put a Victa one on for now.
New rings arrived today and there spot on, tried them in the bore and they are perfect. Made some gaskets while my son looked on, he was very interested as to why there needed to be a gasket and so the lesson began. I have all the bearings and seals so on Saturday I will take my time and enjoy putting it back together
Hi Paul and ODK Members
Thanks for this exciting update. This posting has attracted a lot of interest.
For one thing, It has been most helpful in Mal's recommendation of JP Pistons.
Clearly, for rare piston or ring needs, JP is probably the first point of call in OZ.
For another thing, the larger Trojan was rarely used on AUS lawnmowers.
I digress now, because I am compelled to say something about photographs.
I know that most images that appear on these forums here are illustrative.
But - some images - do a little bit more - they tell a more rewarding & complex story.
This narrative tells the 'ring story' and the 'son story' in such a nice way; and this is
reflected in the composition of your excellent photograph.
It is an exploration in geometry - circles and squares - but with a twist. Note:
- the rings on their package, but the package is on the diagonal.
- the circles and half circle (almost) of the c/case, cylinder, rings and can.
- the contrast of light table to dark background.
- the gasket that appears on the cylinder base.
- the hammer, with circular head, has more complex connotations.
This photo reminds me of the importance of images as part of the words in
telling the story of members' machinery. For example:-
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=59799#Post59799
Sorry for the indulgence here.
My message: photographs form part of the provenance of members' restorations.
They can clearly add value to machines down the track - but also act as an historical record!
All very interesting.
Hi Jack, your comments are always interesting and much appreciated. So many circles in one picture, the crankcase has 11 alone ! I had a look at the post in your link and have added it to my watched topics to enjoy later, I also realise that I haven't posted a pic of the crankshaft. I took one but didn't post it as it is blurry, it's a very interesting build so I will take another one.
Tapped the crankshaft seals in this afternoon, just a note on the back seal. It goes in the reverse way, why I am not to sure but that's how the original seal was fitted on both of my motors. It does have an alloy cover that keeps the rubbish out though
Hi Paul
That's an interesting observation on the seals.
Crankcase seals are, I guess, unusual; in that they have to work
both ways: the upstroke creating vacuum, and down-stroke creating
positive pressure. I wish I knew more in this area but I don't.
Can these seals be driven in from either side?
I drove them in from the inside but I guess you could fit them from either side.
Was there any wear on the shaft surface?
Ive seen seals in further and upside down so the positioning changes and the sealing lip runs on a good section of the shaft.
It shouldnt matter unless the sealing lip is tapered on a directional 45�, as you would lose a large section of sealing surface area.
Here is the crankshaft, very solid
Big end roller bearing, conrod is quite slim
And one for Jack :-)
HT6: Was there any wear on the shaft surface?
It shouldn't matter unless the sealing lip is tapered on a directional 45�, as you would lose a large section of sealing surface area.
No obvious wear, that's the way the seal is facing in the parts diagram as well
Cool....I assumed you didnt have a manual, Since you said you weren't sure why it was upside down....:)
There does appear to be some wear on both ends? Minimal groove or are they just scuff marks?
Hi HT6,
Surfaces are fine just cleaned them up, I don't have a manual it's all guess work. I found the exploded parts view here
http://www.users.globalnet.co.uk/~pattle/nacc/arc0119.htm
It's pretty much all the info there is on these engines, I was sure which way the seal went just not why ?
Ahhhh....Cool:)
Well at least you found this engine diagram, as it confirms your seals positioning.
All back together fired up, ran and then stopped, sheared the flywheel key ! At least it runs, now I have to find a key.
Muffler and exhaust is off the spare motor as the correct one was still soaking in the cleaner.
Found replacement keys here, in Australia. After an afternoon of computer cross referencing and a lot of searching. Found it by the American reference number 203
http://australianmetalworkinghobbyist.com/store/index.php?route=product/product&product_id=386
Ordered a few spare
Hello Paul
Thanks for the updates.
That mag came up real pretty - and still with the oiled felt
cam wiper. They are a handsome engine.
The story of the key is real detective work.
p.s. Did the key fail because there was no flywheel (bladeholder)?
The Trojan war is almost won.
Hi Jack,
I think the flywheel wasn't pulled down all the way on the taper, I replaced the spring under the cam with another one that was a bit cleaner. But it was also a fraction longer which when compressed under the cam held everything up just that bit more. Blade holder shouldn't make a difference on this one as they can run a pulley or a roller or a mower blade. Pretty versatile little engine.
Hi Paul,
Yes, of course. Thank you.
How do you plan to present the cowl? Will it be painted?
Here's a great ad (detail) I recently found.
A couple of OZ manufacturers took the awkward route of protecting
the engine from shock via a spring clutch. They did this because the
blades were rigidly mounted. The clutches were prone to wearing out
(in doing their job) and in the field repairers would remove the clutch,
giving the engine no protection from shock loads.
Interesting, in the advert it states that there are 3 bearings supporting the crankshaft. I think Victa also stated this in their advertising which of course is correct. A bit misleading to the purchasing public as the Trojan motor has only 2 bearings supporting its crankshaft, I suspect that if there is a third bearing/bush perhaps it is in the clutch assembly. Unless the shaft with the 3 bearings is not the crank but the shaft travelling from the clutch to the blades ?
The crankshaft would only accomodate the clutch assembly, there must be another shaft supporting the spring and blade holder, doomed ! Probably why there are none around now, small fuel tank as well. Just not up to the job, I wonder what other mower you could buy for the same money ?
I was looking at the cowl this morning and there is not enough of the decal and the paint is rubbish so it will get a fresh coat of yellow paint. I will make up a new bracket to take a Victa fuel tank.
Hi Paul
Yes, the 'outrigger bearing' may be above the clutch assembly, but external
to the lower crankcase. I never noticed that before ...
I will link an OGDEN booklet to the record tomorrow. Here is an extract:-
Here is the link to the full booklet HERE.
Postie came today, raced out to the mailbox ....... bloody junk mail !! maybe tomorrow :-(
Picture or Video is worth a thousand words
[video]
[/video]
Awesome Paul!
And a true 1.6 h.p. I bet... smirk
Thanks for the video.
Where's the link?
Originally Posted by HT6
Where's the link?
Video above but here is a link
Hope this works for you
sounds nice , lot of links didnt work last week or so too .
thanks Jack
hope he didnt kill it dead though !!!
Page 2 of 3 1 2 3
18,084 Registered Users
Topics12,748
Posts106,774
Members18,085
