1 members (MarkN), 14,189 guests, and 1,546 robots.
on 14-04-2003 jav8r posted "Ryobi 31 cc trimmer." I also own an older Ryobi trimmer 790R. I've experienced IDENTICAL problems, but w/ a twist...
I opened the single screw side of the carb, cleaned the screen out, and replaced the old fuel lines (which had deteriorated and clogged the screen). It now runs fine except...
It will run (idle and full throttle) for about 10-15 minutes, then slowly "die" as it heats up...to the point of only being able to idle, then not at all. I'll let it cool 10-15 minutes OR open and close the single screw side of the carb, and it'll run another 10-15 minutes until dying again.
Does anyone have any suggestions...THANKS!!
dheideman,
What I want you to do is remove the screen that you cleaned and hold it upto the light and I am sure that you will not be able to see through it.
Replace the screen (you should be able to buy one at your local mower shop). Then run the machine again and all should be OK.
If not you will have to replace the diaphrams and it will run properly.
Question:
Did you check to see if the cylinder did not have any scoring on it (you can see this by taking off the muffler and looking into the cylinder).
Bruce [Linked Image]
SantaAnaWinds, JinxJuno, Kenniffs, Neill M, Peenuke1
18,243 Registered Users
Topics12,778
Posts106,883
Members18,244
