2 members (Red Rum, Onkelzniki), 13,079 guests, and 1,810 robots.
#3560 10/05/03 10:50 PM
cjt
Offline
I have a Tecumseh Vantage 35 that has run impeccably for a couple of years. Now, it has begun to stop after 5 to 10 minutes mowing. After a couple of minutes, you can start it again. If I give it more fuel it still stops, so that does not seem to be the problem. Still, in order to start it after a while, I need to give it some more fuel. Before this season I filled up quite generously with oil. Could that be the problem, or what is it? I would appreciate any tip.
CJT
CJT
#3561 11/05/03 09:09 AM
cjt,
Does the primer bulb suck in when it stops?
Bruce [Linked Image]
[This message has been edited by Bruce (edited 11-05-2003).]
#3562 12/05/03 08:37 PM
cjt
Offline
Yes, it does.
CJT
CJT
#3563 12/05/03 09:19 PM
Ok then.
You will have to remove the primer bulb and take out the small ball bearing that acts as a valve.
Then you clean out the tank and the valve area as well.
Reasemble and it should be ok but if the primer sucks in again you will have to replace the valve part of the primer.
I can forward you information on the procedure but it would cost $10-00 to cover scanning time.
#3564 13/05/03 04:26 AM
cjt
Offline
Thanks a lot!
I'll see how far I get.
Regards
CJT
SantaAnaWinds, JinxJuno, Kenniffs, Neill M, Peenuke1
18,243 Registered Users
Topics12,778
Posts106,883
Members18,244
