4 members (Bonnar_Bloke, Ashgren, looktall, NormK), 4,034 guests, and 1,358 robots.
by Bumps - 30/05/26 12:23 PM
Greenfield Javelin Mk2
by Beefy - 21/05/26 06:22 PM
GX25 Honda
by NormK - 21/05/26 12:33 PM
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
Image Upload Issue
by Bruce - 03/05/26 04:45 PM
by maxwestern - 30/05/26 04:27 PM
by monala - 29/05/26 12:24 PM
by Bumps - 28/05/26 12:36 PM
GX25 Honda
by NormK - 22/05/26 08:25 AM
Sanli height adjustment knob
Victa Powercut design flaws
GXV160 clutch
by NormK - 15/05/26 08:25 AM
#118528 11/07/23 02:25 PM
Just wondering what the thread size is for the Victa taps, I assume 1/8th NPT but want to check before I buy a new tap The tap I have is a plug tap and I can't get it started in the thread
NormK #118529 11/07/23 05:38 PM
I usually grab a tap to check the thread 100 percent but I'm sure from memory they are 1/8 BSP.
They are the same for some old bikes as we know. $3. 61 for the thread tap.
max.
NormK #118537 12/07/23 07:24 PM
I have ordered an NPT and a BSP one so I can see what fits best. I have an NPT plug tap here but I can't get it started and the thread is fairly rusted
NormK #118538 12/07/23 09:14 PM
If you got the screw that you are going to be using then it is fairly easy to determine which as long you got a thread pitch gauge.
1/8 NPT will be 27 TPI; letter "Q" drill use initial hole
1/8 BSP will be 28 TPI; Two starter drill bits. 8.4mm for BSPT and 8.8mm for BSPP. so be careful here as to which you have.
There is as with the SAE two styles BSP threading a taper and a straight; hence a BSPT (tapered) and BSPP (Parallel/Straight) so you can't just a BSP tap and have the right without a bit of shear luck.
Also note BSP is slightly smaller in diameter which mean a plug or bottom tap will not start very easy.
Here I work on Kawasaki engines that uses the BSP threads for the oil pressure sensor. I take SAE NPT threaded sensor and re-thread to BSP thread taking advantage of these smaller size.
This is just something I had to learn a few years ago when I was replacing the Kawasaki oil sensors. I stupidly assumed that all 1/8 threaded oil sensors were SAE. Now I got both a 1/8 BSP tap and die in the tool box drawer.
NormK #118541 13/07/23 12:27 PM
Howdy NormK, maxwestern and AVB,
BSP threads showing up on Kawasaki is a legacy of Japan adopting a lot of British designs early in their automotive industry.
Last edited by Mowerfreak; 13/07/23 12:28 PM. Reason: Blinking auto correct again.
Mowerfreak #118563 30/07/23 01:14 PM
The Japs copied everything early on Mf and refused to sign international copy right laws until their technology greatly improved then
they signed up for copyright.
Datsun / Nissan are an example where the Japs just copied Austin .
Ashgren, Ludicr0us, eguatpatto, Jared.Ashby, monala
17,979 Registered Users
Topics12,730
Posts106,679
Members17,979
