0 members (), 2,872 guests, and 556 robots.
Early Morrison rotary mower
by MikeDD - 12/02/26 09:45 AM
by Bruce - 02/03/26 09:37 PM
by Hawkeye - 02/03/26 02:58 PM
by MowingManiac - 25/02/26 07:19 PM
by NormK - 22/02/26 02:31 PM
by Bruce - 20/02/26 12:02 AM
by Bruce - 16/02/26 12:06 AM
Rover Thoroughbred Model 85
by Bruce - 15/02/26 11:59 PM
by Bruce - 15/02/26 11:49 PM
#118528 11/07/23 03:25 PM
Just wondering what the thread size is for the Victa taps, I assume 1/8th NPT but want to check before I buy a new tap The tap I have is a plug tap and I can't get it started in the thread
NormK #118529 11/07/23 06:38 PM
I usually grab a tap to check the thread 100 percent but I'm sure from memory they are 1/8 BSP.
They are the same for some old bikes as we know. $3. 61 for the thread tap.
max.
NormK #118537 12/07/23 08:24 PM
I have ordered an NPT and a BSP one so I can see what fits best. I have an NPT plug tap here but I can't get it started and the thread is fairly rusted
NormK #118538 12/07/23 10:14 PM
If you got the screw that you are going to be using then it is fairly easy to determine which as long you got a thread pitch gauge.
1/8 NPT will be 27 TPI; letter "Q" drill use initial hole
1/8 BSP will be 28 TPI; Two starter drill bits. 8.4mm for BSPT and 8.8mm for BSPP. so be careful here as to which you have.
There is as with the SAE two styles BSP threading a taper and a straight; hence a BSPT (tapered) and BSPP (Parallel/Straight) so you can't just a BSP tap and have the right without a bit of shear luck.
Also note BSP is slightly smaller in diameter which mean a plug or bottom tap will not start very easy.
Here I work on Kawasaki engines that uses the BSP threads for the oil pressure sensor. I take SAE NPT threaded sensor and re-thread to BSP thread taking advantage of these smaller size.
This is just something I had to learn a few years ago when I was replacing the Kawasaki oil sensors. I stupidly assumed that all 1/8 threaded oil sensors were SAE. Now I got both a 1/8 BSP tap and die in the tool box drawer.
NormK #118541 13/07/23 01:27 PM
Howdy NormK, maxwestern and AVB,
BSP threads showing up on Kawasaki is a legacy of Japan adopting a lot of British designs early in their automotive industry.
Last edited by Mowerfreak; 13/07/23 01:28 PM. Reason: Blinking auto correct again.
Mowerfreak #118563 30/07/23 02:14 PM
The Japs copied everything early on Mf and refused to sign international copy right laws until their technology greatly improved then
they signed up for copyright.
Datsun / Nissan are an example where the Japs just copied Austin .
Wayneo888!, Gerald the draught, spud 1, Ilia, Pugsley
17,869 Registered Users
Topics13,068
Posts107,298
Members17,869
PHP: 8.3.30 Page Time: 0.035s Queries: 29 (0.029s) Memory: 0.6413 MB (Peak: 0.6942 MB) Data Comp: Zlib Server Time: 2026-03-03 20:14:51 UTC
