Hi Geoff
Its worth noting that rideon blades have to cross over - otherwise you would have thin lines in the lawn were the blades miss
It is of importance to 'time' the blades so they don't touch at a minimum - although I believe there is often a specification for where each blade should be in relation to the other to give the least vibration
The blades can not be timed. They are driven by a simple v-belt. But yes the do have cross over cutting wise as they are offset. Basically while the deck is on the mower the right hand blade trails the the left hand blade. As for low vibration it called having the bar blades in balance.
Geobee double check the blade specs. These are Gator type mulching blades. But JD original blades are mulching style blades that are m\no tooth but the specs are the same other than the thickness.
C to C 3-3/4" (the two outer holes)
Center Hole 11/16"
Length 21-3/8" (measured diagonally)
Outer Hole 13/32"
Thickness .187
Type Toothed
Width 2-1/2"
It is worth there are timed bar blade decks but they use a timing belt and timing pulleys.
